1993 Chevy Caprice coolant system
JAKKIA
Other Category problem
1993 Chevy Caprice Engine Size unknown Wheel Drive Type unknown Automatic 130000 miles
i have a 1993 caprice that I just purchased and the car is over heating water is running from the water pump. owner stated that the water pump was replace but needed to be tighten. What is the rreal problem
Feb 3, 2008 at 9:15 AM
BLACKOP555
  • 10,386 POSTS
sounds like the water pump is bad, since its overheating. if the coolant is coming out near the gasket then the gasket could be bad or improperly tightned but if its coming out around the pulley or a crack then its no good.
Feb 3, 2008 at 10:50 AM
