1992 Chevy Caprice 1992 caprice
SOLOWOOD
Engine Mechanical problem
1992 Chevy Caprice V8 Two Wheel Drive Automatic 170.00 miles
I just replaced my fuel pump yesterday and it ran fine. This morning on my way to work it acked the same way and died, i poured gas into the carborator and it starts then dies, i think and hope i bought a bad fuel pump but what do u think it all could be?
Sep 7, 2010 at 2:08 AM
WRENCHTECH
  • 20,760 POSTS
You need to confirm and measure the power supply and ground coming into the pump first. If no problems found there, then you probably do have a bad pump.
Sep 7, 2010 at 2:40 AM
SOLOWOOD
how do i check the positive and ground and what if the fuel pump is good then i check the ingnition module or something
Sep 7, 2010 at 3:38 AM
WRENCHTECH
  • 20,760 POSTS
This is looking like this testing is going o be beyond your abilities. You will need to enlist some help that is familiar with electrical testing.
Sep 7, 2010 at 3:53 AM
SOLOWOOD
what if my distributor rotor is a little black on the inside is it bad
Sep 7, 2010 at 5:49 AM
SOLOWOOD
My distibututor is good and everything inside it is too. When i put fuel in the carbrator it will start then dies a few secounds later. I dont think im getting enouph fuel what do u think it could be?Thanks alot
Sep 7, 2010 at 8:09 AM
