1991 Chevy Caprice Stalling
GAMBIT88
1991 Chevy Caprice V8 Two Wheel Drive Automatic
About a year ago, My engine went after 250k miles. The fuel filter poped off and all the oil drained while I was driving. Well when the spring came I went to a junkyard and got a newish engine.(possably a 5.7 unshure). The car runs good, but when it warms up it starts to stall. It only stalls under 30 mph and usially when I try to reverse or get stuck in traffic but sometimes in turns. I was told it was probably the Idle air valve so I removed that and cleaned it but it didnt help the problem. Is this most likely the problem and if so, How do I test the iac to make sure it works.
Mar 27, 2009 at 6:22 AM
  • 110,251 POSTS
It could be that, a TPS, a vacuum leak... Has the check engine light ever come on?
May 4, 2009 at 3:09 AM
GAMBIT88
ya the engine light comes on sometimes when im on the freeway for a bit and almost always within 10 minutes of using cruise control, but it doesnt seem to affect the drive.
May 14, 2009 at 4:32 AM
  • 110,251 POSTS
If the light has come on, there is a trouble storred in the computer. Take the car to a nationally recognized parts store and have them scan the computer. Most will do it for free, so there is no money out of pocket, and it should identify where the problem is coming from.
Let me know what you find.
May 14, 2009 at 4:41 AM
GAMBIT88
Ive tried but they cant read the problem with the light off and the light goes off when i shut off the car. If i get it to come on again then ill have to run in with the car running. I did the test i read on here about iac valves and the piston on mine didnt move so...
May 14, 2009 at 4:29 PM
