1991 Chevy Caprice Replacing brake lines
86,000 MILES • V8 • 2WD • AUTOMATIC
BALLOONMAN07
I have a Caprice Wagon with decent mileage for a 1991, 86K and it has been sitting for a while and the brake lines have gotten corroded. I will onget a single day's use before all of the fluid would leak out.
I am on a very restricted budget and need to find out what it would cost to replace the brake lines.
Again thanks!
Mar 3, 2008 at 10:54 AM
BLACKOP555
  • 10,386 POSTS
every singnle line? you will only need to replace the one that is leaking but if you do it yourself you can expect to pay about 30 bucks if your doing all the lines if you get brake line and bend it and not get the pre-bent stuff. a mechanic will charge you in the ballpark of 150 where i live but city's are a bit more expensive then out in the country.
Mar 23, 2008 at 8:44 AM
