1989 Chevy Caprice pedal to the floor
RHONDAJEAN
  • 6 POSTS
Brakes problem
1989 Chevy Caprice V8 Two Wheel Drive 200,00 miles
Hi so I lost my brakes comp-letly the other day. Went under car and found my brake lines disentgrated. So no problem replaced those, bled hte brakes all good. Started the car pedal to the floor again. Even repalced the power booster aand master cylinder, what a PIA so now what can it be?
Apr 24, 2009 at 1:30 PM
  • 31,937 POSTS
Hi there,
thank you for the donation,
My first thoughts are that you still have air trapped in the system, i would start with bleeding the master cylinder and then the rear brakes then the front, always make sure that you never let the master cylinder run low on brake fluid, bleed into a clear container and keep an eye on the bubbles if the system continues to bubble, you will have air entering the system, start here and report how you get on.
mark (mhpautos)
Apr 24, 2009 at 10:13 PM
