Hello and thanks for the donation!
REMOVAL:
Disconnect the negative battery cable. Remove the door trim panel and the inner panel water deflector.
Raise the window to half-up position.
Punch out the center pins of the glass to sash channel attaching rivets.
Remove the front window channel and bolt.
Using a 1 / 16 inch drill bit, drill out the attaching rivets on sash channel.
Lower the glass to remove from the sash channel and remove the glass from the door.
INSTALLATION:
To install, remove the drilled out rivets and shavings from the door.
Check the rivet bushings and retainers on the glass for damage. If necessary, remove the bushings using a flat-bladed tool covered with a cloth body tape. Install by snapping rivet retainer into the bushing.
Lower the glass into the door and position on the sash channel so the holes in the sash line up with the holes in the bushings and retainers.
Using rivet tool J-29022 or equivalent, install 1 / 4 inch peel type rivet (part No. 20184399 or equivalent) to retain the glass to sash channel.
Install the rear guide channel.
Before installing the trim parts, check the window adjustment for proper fit.
Install the inner panel water deflector and the door trim panel.
Oct 9, 2009 at 6:57 AM
