My car is losing power steering from the lower area. It is not any of the lines and appears to be a steady stream from where the pitman arem connects to the knuckle. Do I need to replace the steering gear or is there a bushing in the pitman arm that can be replaced. Again it is coming from the pitman arm connection nut. Would like to know if there are any seals in this area?
Aug 14, 2008 at 12:10 PM
