we performed overhaul on my caprice,we change all overhauling kit,we put sleeve,we replace pistons,piston ring,valves,we refaced cylinder heads,but when we start and run the engine,drive and use it about a week,the trouble appears,sometimes the engine stall when the temperature reach before 1/2 of the gauge,sometimes when you shift the gear,when you turn on the aircon ditioning,when you make a turn,but mostly when the engine temperature reach that level........hope for your kind and respectful professional response,thank you and more power to your site.
Mar 19, 2008 at 7:22 AM
