1991 Chevy Caprice My car won't shift past 2nd gear!!!
10,900 MILES • V8 • 2WD • AUTOMATIC
PLATINUMQUTE
My car won't shift past 2nd gear. I checked and added transmission fluid to it and coolant also ad I noticed it was low and when I did I could only get it to switch to 3rd gear and it was "red lining" the whole time. When I parked the car I noticed smoke coming from the engine and smelled coolant so I opened the hood and Copland had spewed every where! All over ge engine and a pool under and spilling behind the car. Do you think I need a new tranny?
Jun 7, 2010 at 2:02 PM
  • 75,988 POSTS
Its spewing out coolant bcuz you are over working a slippping tranny causing it to overheat end of results you need a tranny
Jun 7, 2010 at 2:28 PM
