1991 Chevy Caprice front end shakes
265,389 MILES • V8 • 2WD • AUTOMATIC
KEVINLOKEN
  • 74 POSTS
when im on the highway the car shakes when i slow down yes i know my brkaes need to be changed my question is does it sound to you guys like my rotors are warped from to much heat from braking i was thinking of cahnging rotors anyways is it possible to go a bigger size on calipers so braking isnt so hard on the car ? and if so is it hard to do change the whole braking system pads rotors calipers ?
May 30, 2008 at 4:19 PM
MERLIN2021
  • 17,250 POSTS
With this kind of mileage, it can be brakes, can also be worn front end parts, the cost of oversizing brake parts is not worth the expense if you aren't racing it! Change the rotors and pads, go with a brand name rotor, not the el-cheapo chinese ones...
May 30, 2008 at 11:53 PM
