Windows not working?
ZWEETP69
My driver side window on my '91 caprice classic will not roll up. All the other windows work fine but the last time I rolled my window down, it has not come up since. It is electric and this is the only window that has the problem. Any suggestions?
sincerely
Ann
Mar 28, 2008 at 9:08 PM
MERLIN2021
  • 17,250 POSTS
Remove the trim panel, grab a test light, unplug the motor's connector and test for power, if power gets to the connector when the switch is pressed, replace the motor...if no power from switch, replace switch. This guide can help us fix it
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Mar 28, 2008 at 10:45 PM
