1991 Chevy Caprice chugging
262,000 MILES • V8 • 2WD • AUTOMATIC
KEVINLOKEN
  • 74 POSTS
u guys told me it may be my egr valve it was wierd after u told me that my car ran fine all of a sudden but then just the otehr day it started chugging again but this time it was worse it chugged as long as i had my foot on the gas when i let off it would shake but thats it they i would go to go up a hill and put the gas down alittle further then it would almost backfire but not a loud exhaust backfire it was wierd then i would hit the brakes and it would die all of a sudden start up np at all i dont know what to do ,the car just doesnt sound or run the same as it did and i also noticed with my throttle body injection that when i pull the air filter off there was gas on the filter cause the injectors r right ther so i dunno
Mar 4, 2008 at 4:43 PM
BLACKOP555
  • 10,386 POSTS
what i want you to do is go to the forums mainpage, after your loged in select view your posts then go find your original topic and reply there and the tech that has been helping you so far that has more information about your problem then me will be able to further help you, provide in your reply the same information you posted here.
Mar 23, 2008 at 8:42 AM
