1991 Chevy Caprice can the transmission be configured from
215,000 MILES • V8 • 2WD • AUTOMATIC
DIABLOVOX
  • 5 POSTS
is it possible to change transmission setting by hooking something to the car comp.? can something like this have effects like smooth or jerky gear change? what exactly can i use to tune the car comp?
May 13, 2008 at 3:32 AM
PEAR69
  • 1,482 POSTS
Yes, it is possible to tune the transmission with a computer scan tool. The type tool you need is a Gm Tech 1 or -equvalent- scan tool with the proper hardware for the purpose you intend to use it for. The problem is this scan tool with the hardware you need is around $9000.00 plus tax, and you have to go to school to learn how to use it.
May 18, 2008 at 7:37 PM
