everything has been check. themst. ok fan ok. Where is the fan relay located?
Aug 17, 2009 at 1:30 AM
JDL
✓Experienced Mechanic
Hello, underhood, firewall, driver side of brake booster. To double-check, look at the connector wiring colors, check against wiring diagram. Did you check the coolant temp sensor?
Aug 17, 2009 at 3:18 AM
