1991 Chevy camaro fan relay
90,000 MILES • V8 • 2WD • MANUAL
ROYALLEN
everything has been check. themst. ok fan ok. Where is the fan relay located?
Aug 17, 2009 at 1:30 AM
JDL
  • 16,098 POSTS
Hello, underhood, firewall, driver side of brake booster. To double-check, look at the connector wiring colors, check against wiring diagram. Did you check the coolant temp sensor?
Aug 17, 2009 at 3:18 AM
