1989 Chevy Caprice PROM chip
13,700 MILES • V8 • 4WD • AUTOMATIC
WIL3016
I have the above mention car. I was driving down the road and the car lost power and stalled out. When tried to restart, it would not start but would turn over. I replaced the ignition coil, ignition module and it still want start but turn over. I also took out the #1 plug to see if I was getting a spark and no fire to the plugs. I also tested the wires from the coil and module and get less than a 1/2 volt reading. What could be my problem 1. Bad PROM chip, if so, how can you test the PROM chip.
Look forward to hearing from you
Sep 12, 2010 at 1:14 AM
  • 75,988 POSTS
Test the coil's primary and secondary winding resistances to include the distributor pick-up coil and for short to ground
Sep 12, 2010 at 1:22 AM
WIL3016
I checked the pic-up coil and it gave me a good reading indicating that it was good. what do I do next?
Sep 12, 2010 at 2:08 AM
