1988 Chevy Caprice NO POWER
84,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOXCHEVY
WHY DOES MY CAR WONT START? THERE IS NO POWER AT ALL. BATTERY IS FULLY CHARGED. STARTER IS NEW. BUT SOME OF MY WIRES MELTED BUT I REPLACED THE WIRES THAT WAS MELTED. AND I GOT NEW RELAYS ALSO BUT NOTHING HAPPENED. IT STILL WONT START.
Sep 2, 2010 at 1:58 PM
JDL
  • 16,098 POSTS
Check for voltage feed to the ignition switch, red wires, see if they are hot, use a testlight. They should be hot all the time. If not, check fusible links, my info says links come from starter solenoid, bat terminal. Use a testlight check for voltage to the links and from the links. My wiring info for your model year isn't that great.
Sep 3, 2010 at 3:43 AM
