1988 Chevy Caprice BRAKE LIGHTS WONT GET BRIGHTER WHEN I AM
140,000 MILES • V8 • 2WD • AUTOMATIC
ALEXTRUBEK
  • 13 POSTS
MY BRAKE LIGHTS COME ON WHEN I HAVE THE CARS HEADLIGHTS ON, AND THE TURN SIGNALS ALWAYS WORK, BUT WHEN I PRESS THE BRAKE DOWN, THEY DONT GET BRIGHTER TO SIGNIFY THAT IM COMING TO A STOP. THEY ALSO DONT COME ON IN THE DAYTIME WHEN IM NOT USING THE HEADLIGHTS, AND I PRESS THE BRAKE PEDAL DOWN. STUMPED!!!!!!!
Sep 5, 2010 at 1:59 PM
  • 31,937 POSTS
I would say the side lights or parker's are on and the brake lights are not working, so check the brake light fuse and check the brake light switch mounted at the top of the brake pedal under the dash.
mark (mhpautos)
Sep 5, 2010 at 4:24 PM
ALEXTRUBEK
  • 13 POSTS
Just got the stop light switch by the brake pedal replaced, and put a new fuse in for the brake lights, even tho the old fuse was good. Still not working.STUMPED x2!
Sep 6, 2010 at 2:05 AM
  • 31,937 POSTS
Hi there,
You will have to check power at the fuse with a test light, at the switch, through the switch and at each loom plug, if you have power, then check the brake light earths.
mark (mhpautos)
Sep 6, 2010 at 2:13 AM
ALEXTRUBEK
  • 13 POSTS
Used the power light to check all the powering, everything is good. Even the new stop light switch i just put in by the brake pedal is working properly, as far as power and switching on and off goes. My uncle says it could possibly be the turn signal switch? Not to sure of his car knowledge sometimes tho. lol
Sep 6, 2010 at 3:13 AM
ALEXTRUBEK
  • 13 POSTS
Just fixed it myself! It was a small white wire that goes in with the connector for the turn signal switch under the steering column. The wire had come out of the connector, so i stripped it a little and reconnected it. Works perfectly now! And i didnt have to tear my whole dash apart or take off my steering wheel to do it. Thanx for all the help and info! Love this site!
Sep 6, 2010 at 4:31 AM
  • 31,937 POSTS
Hi there,
Thanks for the feed back, that's a good result, thank you for using 2carpros.
mark (mhpautos)
Sep 6, 2010 at 11:21 AM
ALEXTRUBEK
  • 13 POSTS
HERE WE GO AGAIN..... having the same problem again... not the wire this time, and i just got a new brake light switch, checked all my inside fuses as well. this is the 3rd brake light switch i have gone through since ive had this car, and now this new one i just put on is not fixing the problem... ANY IDEAS AT ALL?
Jun 28, 2011 at 5:34 PM
CADIEMAN
  • 3,544 POSTS
the brake light goes through the turn signal switch.you have to get a switch and plug it in without installing then check for brake light operation.if so you will have to install it.
Jun 28, 2011 at 5:54 PM
