1987 Chevy Caprice What a/c compressor+ clutch do I need?
1987 CHEVROLET CAPRICE
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
AARON1312042
  • 5 POSTS
When reference is made to an oil and oil-less a/c compressor, what exactly does that mean? Does it mean the compressor is oil-filled or does it mean the a/c system is oil filled?
My Caprice has a compressor made by Harris (made for GM marked on it) with part 1131636 on it and says "oil". Not sure what part to get. The VIN is 1G1BN51Z5H9124351. Thanks
[img]
http://www.2carpros.com/forum/automotive_pictures/348115_23952395n_1.jpg[/img]
Apr 24, 2009 at 5:37 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Are you converting to 134A ? Have you made a repair? if so what was done. You have a V5 variable displacement and it has no crankcase for oil. Oil is carried through system with the refigerant.
Let me know
Thanks for donate
Apr 24, 2009 at 8:39 AM
AARON1312042
  • 5 POSTS
The car was converted to R134 a few years ago and seems to leak out each year. This year, when I turned on the a/c, the clutch didn't kick in. Also, when the a/c is off and working properly, I usually hear a relay cycle on and off. This year it didn't cycle.
I don't know the details of the conversion.
As I understand you, oil-less means oil is carried through the a/c system?
Apr 25, 2009 at 12:47 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Yes on oil-less statment. Do you have gages to test with? You should have 90psi or more at rest. If you leak freon you remove oil also. You can add oil assuming it is PAG most likely is. And you can add stop leak cause sounds like an evaporator leak also very common to Chevy.
Apr 26, 2009 at 5:51 AM
AARON1312042
  • 5 POSTS
No pressure in system. PAG?
Aren't stop leak products for a/c systems a temporary fix?.
I'll keep the evaporator in mind when I take it into the shop. Auto-Zone guy took a look under the hood and said it was the compressor because there was oil on it, but I had sprayed the belt with silicone.
Think I should take it an AC Delco repair shop? So far, 3 local mechanics have disappointed me with minor repairs not related to the a/c.
I spoke to my current mechanic and he said that "you just have to live with the leaks and recharge it every year". Sounds like they won't take the time to find the leak.
Anyone know any competent mechanics in Jackson, NJ? thanks
Apr 26, 2009 at 2:14 PM
DOCFIXIT
  • 18,828 POSTS
Look for an A.S.E. Certified shop that specializes in AC repair. If leak becomes hard to find ask for Dye to be put in system then the dye glows flourscaint geen where leak is.
Apr 27, 2009 at 8:48 AM
AARON1312042
  • 5 POSTS
Will do. thanks.
Apr 28, 2009 at 2:08 AM
