1986 Chevy Caprice timing chain
IVORY COOPER 855
Engine Mechanical problem
1986 Chevy Caprice V8 Two Wheel Drive Automatic
my car jump timing and i bought a new chain and gears i installed them and set both arrows facing each other but my vehicle wont start how do i set the timing on the distributor
Jul 19, 2008 at 9:27 AM
MASTERTECHTIM
  • 4,750 POSTS
make sure the harmonic balancer is on 0 and your on the compression stroke for #1 cylinder(this is done by removind #1 plug and bump the key until you get compression out of the spark plug hole) line the rotor up with the #1 spot on the distributor cap and see if she runs
Jul 19, 2008 at 9:42 AM
