1986 Chevy Caprice it just shuts off !!
12,024 MILES • V8 • 2WD • AUTOMATIC
LEOTHELION56
after about 5 miles or 5 min.s if i\I release the gas throttle it will shut off.will not restart till it cools down {10 to 20 min.s) But will not stay running. I removed the air breather top & held open the choke ,but to no avail.It has a four barrel & their seems to be a constant clicking in the carburetor when the ignition is in the on position. The car belongs to my daughter. > Thank you for your help <
Jan 6, 2010 at 8:28 AM
ERNEST CLARK
  • 1,730 POSTS
I can't really think of anything that would produce a clicking sound from your carburetor. And I haven't even worked on a carbureter for quite some time. But I'll try to give you a couple places to begin looking.
When you experience a mysterious shut off of your engine after a few short minutes of operation, it's almost always a spark, or fuel related problem.
As for spark, your coil could be going bad. (Internal wires are broken/shorted) What happens is, while the engine compartment is cold, the coil will work properly, but as the engine runs, the radiant heat, combined with the heat of the coils normal operation will be enough to separate the internal windings or short them out. And it will stop functioning until it cools down.
As for your fuel system, you could be experiencing a host of problems. Your fuel lines could be experiencing "Vapor lock". Which happens when your lines build up too much heat and it boils the fuel.
You could have a sticking float/needle assembly, which won't be able to keep up with your motor's fuel demands. (choking it off)
Your fuel pump could be failing, your fuel filter could be clogged, or your carburetor may have an internal passage that's clogged.
There's so many things that could go wrong with a carburetor r and cause your described symptoms s. That's why fuel injection was invented!
The first thing for you to check is your ignition system. Once you can eliminate that, then look into your fuel system, starting with the simple stuff.
With 120K plus miles, it may be time for a cab rebuild anyway.
Jan 11, 2010 at 12:39 PM
EDDIE485
  • 7 POSTS
My car didn't want to turn on any more from a bad fuel pump.but I changed the pump and it ran good for about 20 min then it shuts off and wont start till it cools down.
The fuel needle didn't work so it always showed fuel tank.so I tide the needle up with wire. Also the fuel strainer also mes up but i tide it up with thin line of wire, can this be messing up the fuel pump causing it to shut down and choke like you said??????
Apr 24, 2014 at 10:14 AM
