1986 Chevy Caprice battery not gettig charged
PROUDCHEVYOWNER1
Electrical problem
1986 Chevy Caprice V8 Two Wheel Drive Automatic
my battery is not getting any charge, has new starter, new alternator and new silinoid
Aug 18, 2009 at 8:57 AM
JMALECKI
  • 118 POSTS
Hello
Check the fusable link at the starter it is an extra wire that gets connected to the starter with the battery cable and runs to the alternator to allow it to charge the battery. The wire acts as a fuse and will burn in two inside the insulation.
john
Aug 18, 2009 at 3:00 PM
PROUDCHEVYOWNER1
Hello john,
I checked the cable u said to and that is not the problem. I just put it in today. When i use my signals my hazard lights and all four signals turn on.. Any other ideas? oh yeah my stearing colume is not the original one..
Thanks, Jr.
Aug 19, 2009 at 3:49 PM
JMALECKI
  • 118 POSTS
Hello again
well it sounds like you have a short somewhere, to bypass all this you can run a wire from the battery terminal on the back of the alternator to the possitive battery cable at the battery this should take care of the no charge problem.
John
Aug 20, 2009 at 10:01 AM
PROUDCHEVYOWNER1
There is already a wire existing like that..
Jr
Aug 20, 2009 at 12:35 PM
JMALECKI
  • 118 POSTS
Jr
then the alternator should be charging the battery, check to see if there is battery voltage at that wire also check to see that there is voltage at the 2 wire plug with the key on.
John
Aug 21, 2009 at 12:44 PM
