1985 Chevy Caprice Lower Ball Joint
111,000 MILES • V8 • 2WD • AUTOMATIC
DAVIDC509
My passenger side lower ball joint keeps strippiin off and breaking the cotter pin??? I have changed all other ball joints with no problem but for some reason this side keeps pushing itself out
Feb 21, 2010 at 10:35 AM
ERNEST CLARK
  • 1,730 POSTS
There has to be either a bent control arm/steering knuckle, your rim is bent, or there's a sever alignment problem.
There's something causing that side to load enough to break the ball joint. You'll have to put your car on an alignment rack.
Mar 7, 2010 at 12:40 PM
