1985 Chevy Caprice
AALTAMI4
Engine Performance problem
1985 Chevy Caprice 6 cyl Two Wheel Drive Automatic
i have this chevy caprice 85 and when i try to start the engine turns but doesnt start not even when i pump the gas. alternator spark plugs fuel pump and fuel filter are all good. fuses are good. what can be wrong? what can i do to get it to start??
Nov 25, 2008 at 9:24 AM
  • 110,248 POSTS
Hi:
If you are getting spark to the plugs and gas, the car should run unless it's out of time or has little compression. Have you checked that? Also, you say the spark plugs are good. Are you getting spark to them?
Nov 29, 2008 at 2:44 PM
