1980 Chevy Caprice POPPING IN THE CARB
96,754 MILES • V8 • 2WD • AUTOMATIC
BIRDMAN21
I HAVE A 1980 CHEVY CAPRICE LANDAU IT POPPING OR BACKFIRERING IN THE CARB AND NOT OUT THE BACK WHAT IS THAT I VE CHANGED THE TIMING CHAIN A FULL TUNE UP I DONT WHAT ELSE TO DO CAN YOU HELP ME
IT POPS WHEN YOU HIT THE GAS
Apr 23, 2008 at 2:35 AM
  • 75,988 POSTS
Check the accelerator pump if its squirting fuel when you hit the gas pedal and also the fuel pressure.
Apr 23, 2008 at 2:56 AM
BIRDMAN21
its not squirtin gas its popping when you hit the gas and the spark plugs are full of gas
Apr 23, 2008 at 3:10 AM
  • 75,988 POSTS
Time to rebuild the carbuerator-the Acc. pump is not working its suppose to squirt fuel every time you pull back the throttle.
Apr 23, 2008 at 10:10 AM
