1980 Chevy Caprice engine trys to start after the key is tu
ZACKYBIGGZ
Engine Mechanical problem
1980 Chevy Caprice V8 Two Wheel Drive Automatic
i jus dont know what the problem could be
Dec 30, 2009 at 1:42 AM
JDL
  • 16,098 POSTS
Welcome to the forum, need a little more info. Your saying it trys to start after the key is turned off? Usually the feed to the ignition coil is ignition feed, goes hot when you turn on the key.
If your saying, the starter tries to crank, I'd check ignition feed to starter solenoid, small terminal.
Dec 30, 2009 at 2:49 AM
