1977 Chevy Caprice Engine Compartment/Wheel Well Protective
CAPR1CEPR0SE
  • 10 POSTS
Engine Performance problem
1977 Chevy Caprice V8 Two Wheel Drive Automatic
I am trying to replace the "Composite" Sheathing/Shielding Material that's secured to the "Engine-side" of the Front Wheel Wells w/Plastic Push-Pins, and protects the engine from the Weather & Street elements.
I am hoping that you can inform me as to (1.) the "proper name" for this "Gasket-like" Sheet Material; (2.) the actual composition or make-up of this particular "protective" material; and, finally, (3.) where I can obtain this material - either as a "custom" or "Bulk" roll product.
I look forward to your response.
Sep 15, 2008 at 8:10 AM
2CARPRO JACK
  • 11,533 POSTS
Either a restoration specialty shop or the dealer.Not really sure of the exact name, but the dealer can bring up a picture that you can point out what you need and then they can find the exact name.It is a heavy rubber material similar to mud flaps.
Sep 16, 2008 at 12:51 AM
CAPR1CEPR0SE
  • 10 POSTS
Dear Jack,
Thanks very much for your quick and comprehensive response to my question!
Very much appreciated!
Sep 16, 2008 at 8:58 AM
