1972 Chevy Caprice points
80,000 MILES • V8 • 2WD • AUTOMATIC
ROBGOSS33
I replaced the points and set the dwell to 30 degrees like the sticker under the hood says. now im getting very weak and intermittent spark to the plugs. the car ran when i started just idled rough in gear. im stumped.
thanks
Apr 8, 2010 at 2:22 AM
DOCFIXIT
  • 18,828 POSTS
Make sure you are reading dwell meter for eight cylinder cause sounds like dwell is low. You can set with feeler gague .017-.019
Apr 9, 2010 at 2:51 AM
