Is it bogging, Or u talking about when u get to max speed on the speedo?.
Jun 23, 2007 at 10:46 AM
KIRBSTER269
MEMBER
ecm has a rev limiter set on the car that at a factory setting it will cut the fuel off not completely just a quick off and on only way to get rid of that you have to reprogram the ecm expensive and unless you are dragging professionally not recommended
