What would cause..
KIP EDENS
A '95 Z28 Camaro to cut out on top end?
Jun 20, 2007 at 2:56 PM
E40WATER12
  • 522 POSTS
Is it bogging, Or u talking about when u get to max speed on the speedo?.
Jun 23, 2007 at 10:46 AM
KIRBSTER269
  • 14 POSTS
ecm has a rev limiter set on the car that at a factory setting it will cut the fuel off not completely just a quick off and on only way to get rid of that you have to reprogram the ecm expensive and unless you are dragging professionally not recommended
Jun 24, 2007 at 10:41 AM
