water pump
ONEILLSURFER69
im having a problem with my waterpump or cooling system i just put a new pump in and i lose water but i dont leak i have to fill every couple days i have no problems with overheating or anything does anyone know what it could be?
Jun 2, 2007 at 4:16 PM
MIKE H R
  • 3,094 POSTS
did you loose coolant before you put the water pump on? check the connection and hoses. there could be a small leak that evaporates showing no visable leaks. if iyou were loosing fluid before the pump was put on it could mean internal problems.
Jun 3, 2007 at 3:09 AM
