98 Chevy Camaro, 3.6L v6 with 175,000 miles. Car was overheating, replaced bad thermostat, car still overheated, water leaking from the water pump, replaced water pump. Car seemed to be running fine, then the next day oil pressure dropped and car stalled out. Put oil in it, car started back up, but would sputter and die. Now there is water in the oil. Drained the oil, removed the water pump, changed water pump gasket and replaced it. Put new oil in and still have water in the oil. How is the water getting in there? Any information would be appreciated. What is the best thing to do to fix this problem?
May 6, 2007 at 11:15 AM
