Stuck at 3500 RPM @ 60-70 mph
THEHATGUY
I have an 3.8L '02 Camaro with 82k miles. The car was driving normal until I went to pass at approx. 70 mph, and it lost its power. The car drives normal at low speeds, but it will not achieve over 3500 RPM when accelerating at high speeds or going up steep hills. It does make some noise when trying hard to push it over. Check engine light diagnostics revealed a forward oxygen sensor. I replaced the sensor, and reset the light. This did not fix the problem. While revving at idle the engine sounds strong, and there are no exhaust odors. So it doesn't sound like a catalytic converter or exhaust problem. Does it sound like a bad Manifold Air Pressure (MAP) or Mass Air Flow (MAF) sensor even though diagnostics don't indicate it? If so which one? Any suggestions are appreciated. :)
May 20, 2007 at 4:59 AM
THEHATGUY
I had an engine diagnostic run, and it indicated a bad catalytic converter. I had the converter replaced, and it fixed the problem. The engine diagnostics cost ~$50 (with coupon) and the converter with installation was ~175. The converter would have been covered by warranty had it not turned over 80k miles. Isn't it funny how warranties work like that...
May 29, 2007 at 1:21 PM
