Chevrolet Camaro No Money For Donation But Its Serious
CHEVROLET CAMARO
TYC
1995 camaro 3.4L V6 136,000 miles, recently my oil pressure has droped to about 20-30 but if i idle at a stop it drops to 0 and my thermostat jumps up and down, no oil in coolant and no coolant in oit, please help
Mar 19, 2007 at 5:24 PM
SERVICE WRITER
  • 9,123 POSTS
There is a good chance there is a bearing going bad. You need to pull the belt back off the pullies and spin each one. Feeel for roughness or slight binding. My bet is the alternater, it will still charge okay (but the life of it is numbered.
Before you do that, take a real long screwdriver or bar witha handle. Touch it to each component's housing and put your ear on the handle, using it as a stethescope. You'll hear where the roughness is and begin to isolate it.
Jan 8, 2007 at 8:48 PM
EGILLIAM
  • 11 POSTS
My car is a 1991 camaro 3.1 now I know that this is a different engine but we replaced the oil pump and it fixed the problem. Hope this helps.
Mar 20, 2007 at 1:29 PM
