1992 Chevrolet Camaro No Start
GR33DY GRIM
I have a 92 RS Chevy Camaro with about 215,000 miles right now. Its an automatic with the 305 V8. Its not starting and when i went to check to see if it was getting gas it was just blowing air. So that means its the fuel pump needs to be changed right???
Sep 1, 2007 at 11:17 AM
  • 75,988 POSTS
[quote:0f788b2f45="Gr33DY GriM"]I have a 92 RS Chevy Camaro with about 215,000 miles right now. Its an automatic with the 305 V8. Its not starting and when i went to check to see if it was getting gas it was just blowing air. So that means its the fuel pump needs to be changed right???[/quote:0f788b2f45]
Wrong! maybe you got correct fuel pressure from the pump but the injectors are not energizing because the computer is not getting an igntion signal to activate the injector/s.
Sep 1, 2007 at 12:07 PM
  • 75,988 POSTS
Check all these things before you replace the fuel pump;
1. On the relay bracket at left side of firewall in the engine compartment is where the fuel pump relay is located.
2. Fuel pump fuse is near battery
3. Fuel pump and oil pressure switch on lower left side of engine.
4. The fuel pump is in the tank.
Good Luck
Sep 1, 2007 at 4:46 PM
Suggested Repair
Do not replace the fuel pump yet. Check the fuel pump relay on the left firewall relay bracket, the fuel pump fuse near the battery, and the fuel pump/oil pressure switch on the lower left side of the engine. Also consider that the injectors may not be energizing if the computer is not receiving an ignition signal.
Conversation Summary
The owner of a 1992 Chevrolet Camaro RS with a 305 V8 has a no-start and found only air when checking for fuel, so they assumed the fuel pump failed. The expert said that may be incorrect and that the injectors may not fire if the computer lacks an ignition signal. Before replacing the in-tank pump, check the fuel pump relay, fuse, and oil pressure switch.
