Freeze plugs on the engine block
CHEVROLET CAMARO
91CAMAROGUY
I am having a problem with my 1991 Z28 camaro with a 350 engine when i add coolant to the car i leaks right back out but not from the radiator or water pump it seems to be leaking from above the crank shaft do i have a leaking freeze plug or should i be worried of a cracked block? Furthermore do i even have a freeze plug in that area ? any ideas would be helpful .
Feb 23, 2007 at 3:08 PM
KIN CHAN
  • 453 POSTS
yup...its got a few freeze plugs around the side and the back of the block ....crawl underneath and start looking....later
Feb 23, 2007 at 11:01 PM
MIKE H R
  • 3,094 POSTS
there are freeze plugs on the lower sides of the engine. try to pinpoint where it is leaking, it could be
from a couple of things, check the , thermastat housing and hoses. lintake manifold, pressure check the engine coolant system. it sould pinpoint where it is leaking.
Feb 24, 2007 at 1:41 AM
