1984 Z28 Camaro 350 5 sp ~ 125000 miles
When I press in the clutch pedal, it goes all the way to the floor with no resistance. This happened once before several years ago, it was the slave cylinder then. Just wondering if there were any other causes for this behavior? It will still start if the pedal is pushed in, but shifting is impossible while the engine is running.
Apr 22, 2007 at 3:38 PM
