I have a 1998 Camaro 3.8l auto 150000miles It overheats.
I have replaced the radiator water pump temperature switch and fan relays. The fans come on when the A/c is on. They do not always come on when the cars is hot. It does not always overheat. I have bled air from the system with the bleeder screw at the thermostat housing. I have flushed the system several time. It does not always seem to flow water at the radiator cap.
Thanks
AL
Thanks
AL
May 15, 2007 at 12:16 AM
