Camaro Hood
JD082983
I am trying to hook up my hood scoop. It has a wire comming out from under the hood and i dont know what to hook it up to. I know when i hook it up that when i step on the throttle the hood scoop will open to get more air in the engine but i do not know what to hook it up to??? Any ideas?
Jun 20, 2006 at 2:11 AM
TCOOPER
  • 8 POSTS
Look at the wire and se if it is two wires that needs to be hooked to a power source. Find a key hot and the ground it to the chassis. That might work. Unless it is a vaccum line then hook it to the vaccum tree on the manifold.
Jun 20, 2006 at 5:08 AM
