Is it possible to swap a 305 5.0 tbi 5 speed from a 91 rs to a 95 camaro that is an automatic?
May 20, 2006 at 3:41 AM
FASTCAMARO86
MEMBER
yes you can put that motor and trany in there but you would have to put in the clutch peddle and shifter in the car and you would have to take all the clutch hydrolic master cylinder and slave cylinder along with it
May 20, 2006 at 6:42 AM
RALLEYEGIRL
MEMBER
what about the motor mounts etc...???
May 23, 2006 at 8:43 AM
FASTCAMARO86
MEMBER
the motor mounts should line up just fine there is nothing different between the out side of the motors as far as mounting holes. the motor should just slip right in.
May 23, 2006 at 11:22 AM
RALLEYEGIRL
MEMBER
ok the 95 is sequential fuel injected and the 305 is a tbi what would have to be done about that?
