Normally if a cracked head is from getting to hot, even then its ifee either way it needs repair I would check the gasket first then besides you said antifreeze wasnt mixed, with oil, antifreeze came out first then oil, normally when the 2 mix (engine running) it ends up looking like chocolate milk on the dipstick unless your in a hurry or have money to burn I would check this first good luck
SPONSORED LINKS
Sunday, June 24th, 2007 AT 9:53 PM
