99 Camaro DRL/Headlight Problem
N5TP
Before the failure of whatever failed, I had always been able to leave my headlight switch ON, and it would automatically turn the running lights on during daytime and turn the headlights ON at night. Plus, the headlights would go off when I turned the ignition OFF. Now, the headlights stay ON, even with the ignition OFF. I must turn the headlight switch OFF in order to turn the headlights OFF. I have replaced the DRL Module, but that had no effect on the problem. The little light in the A/C vent flashes when the door is opened, even when the ignition is OFF. I think this is normal.
Can someone please tell me what has failed? Or can you tell me where to go to find the answer?
Apr 9, 2007 at 2:56 AM
2CARPRO JACK
  • 11,533 POSTS
How about the light sensor on the top of the dash?
Apr 10, 2007 at 1:13 AM
N5TP
Is this sensor the same small light in the A/C vent that flashes when I open the door and the ignition is OFF?
Apr 10, 2007 at 1:55 AM
