97 Camaro V6 A/C
DJBAUER2_2
the a/c in my v6 camaro has been blowing hot air for the past few weeks. i had refridgerant put in it... but the line from my compressor going into the interior of my car would freeze over and my temperature gauge would slowly rise, causing the engine to overheat. once i shut off the a/c, my temp. would go back down to normal running temp and the line would defrost. what should i do to fix my problem?
Jul 1, 2007 at 7:04 PM
E40WATER12
  • 522 POSTS
Either you got a blocked line or a leak from youre AC lines, When u kick youre AC on does youre cooling fan kick on?. Also youre AC compressor pump could be shot, Also need replacing. Might have to get line pressure test done,
Good Luck.
Jul 2, 2007 at 10:23 PM
