94 camaro, stalling problems
CRUNCH17
i have a 94 camaro z28, 5.7L 6-speed, and for the past 2 weeks my car has been running funny. It runs good for the first 10 minutes or so but after a short while my rpms go down to about 800rpm and my oil pressure drops to about 20(from 35-40). Once this happens it starts to stall. Theres two times when it stalls, when im stopped or slowing down my car will just completely shut off. And the other time i could be on the highway and when i go to hit the gas nothing happens and soon after it shuts down. I can start the car right back up no problem. I have replaced my fuel filter(which was in pretty bad shape). Ive been told to replace my fuel pump, and have also been told to replace my ignition module. Any ideas?
Feb 11, 2006 at 1:58 PM
MVANNESSJR
  • 223 POSTS
A clogged fuel filter will cause the fuel pump to eventually fail. If your fuel filter was really bad, it is very possible the fuel pump is in the same condition.
Feb 11, 2006 at 2:46 PM
SERVICE WRITER
  • 9,123 POSTS
Did you find out the problem?
May 21, 2007 at 12:52 PM
