91 camaro clunking in rear end
1991 CHEVROLET CAMARO
91CAMARO
  • 7 POSTS
i have a 91 rs 3.1. at speeds of 40 and up if i let up off the gas or touch the gas there is clunk that seems to be coming from the back of the car. dont know what it is.
Jan 13, 2006 at 2:27 PM
PALCO
  • 83 POSTS
how many miles on the u-joints? and have you changed the lube in the differential, its suppost to be changed every 35000 to 45000 miles. most people don't do this service as needed. resulting in failure. good luck
Jan 13, 2006 at 3:19 PM
91CAMARO
  • 7 POSTS
i put new u joints on it. same problem. added fluid..same problem.
Jan 13, 2006 at 6:54 PM
PALCO
  • 83 POSTS
change the rear end fluid is what i was getting at you might find chunks! a second thought is maybe the suspension arms bushings, where they attach to the rear diff. and/or the frame. good luck
Jan 14, 2006 at 2:53 AM
