91 camaro 3.1 idles fine but almost dies
1991 CHEVROLET CAMARO
CEODOM
  • 13 POSTS
I have a 91 camaro RS 3.1 v6 I recently purchased. A lot of parts have been replaced on the engine. There is only one problem. When i press the accelerator, it seems as if it is going to die. if i let off and gradually give it gas it will rev up but at certin points it will start to bog down again. i replaced all the plugs and wires and the TPS(throttle position sensor) today. It still has the same problem. Also the fuel pump, filter, ECM, Prom chip, Distributor and air filter were replaced Could someone PLEASE tell me what is wrong with this vehicle. I am at my wits end. I am not getting any check engine lights either so i am really puzzled
May 18, 2006 at 2:16 PM
CASPERL
check your m.a.f. sensor with your volt o meter your repair manuel will tell how to check it before you buy it let me know how it goes
May 18, 2006 at 3:55 PM
CEODOM
  • 13 POSTS
[quote:5cc6016d1d="casperl"]check your m.a.f. sensor with your volt o meter your repair manuel will tell how to check it before you buy it let me know how it goes[/quote:5cc6016d1d]
I dont have a Mass Air Flow sensor.
May 18, 2006 at 7:43 PM
