1992 Chevy Camaro fuel delivery problem. car is getting way
1992 CHEVROLET CAMARO
174,000 MILES • V8 • 2WD • AUTOMATIC
CHEVYG20
  • 8 POSTS
im getting to much fuel my 1992 camaro rs 5.0L 305 v8 TBI. its running real rich. ive replaced the cooliant temp sensor, throttle position sensor, fuel pressure regulator,spark plug and wires, distributor cap and rotor, ECC and the ignition coil, idle air control valve and oxygen sensor. how do i fix this problem what else might it be
Jun 9, 2010 at 2:53 PM
Check if the injectors are leaking and also test the O2 sensor.
Jun 9, 2010 at 2:54 PM
CHEVYG20
  • 8 POSTS
[quote:7cd6d89d7d="rasmataz"]Check if the injectors are leaking and also test the O2 sensor.[/quote:7cd6d89d7d]sorry it wouldnt let me send a message so i had to do it this way how do i find out if theres a leak in the injectors. what do i do. thanks
Jun 10, 2010 at 3:03 PM
Turn the key On-It'll be very obvious if its leaking
Jun 10, 2010 at 3:07 PM
CHEVYG20
  • 8 POSTS
[quote:5dc64694e8="rasmataz"]Turn the key On-It'll be very obvious if its leaking[/quote:5dc64694e8].....ok then the injectors definately arnt leaking. i just replaced the oxygen sensor and its still spraying way too much fuel out of the injectors. It wont even start because its getting so much gas. can the injectors be bad even tho there spraying exactly the same. thanks hopefully that helps
Jun 10, 2010 at 4:38 PM
It suppose to be spraying in a mist cone shape pattern-not breaking up/puddles
Jun 10, 2010 at 4:57 PM
CHEVYG20
  • 8 POSTS
[quote:c569a2d3fa="rasmataz"]It suppose to be spraying in a mist cone shape pattern-not breaking up/puddles[/quote:c569a2d3fa]......yea there definately spraying not misting. so does that mean my injectors are bad or does it have to do with something else
Jun 10, 2010 at 5:04 PM
Could also be the fuel pressure regulator leaking too-also test the coolant temperature sensor.
Jun 10, 2010 at 5:07 PM
CHEVYG20
  • 8 POSTS
[quote:66fe1598b8="rasmataz"]Could also be the fuel pressure regulator leaking too-also test the coolant temperature sensor.[/quote:66fe1598b8] the fuel pressure reg. Is new I had a mechanic install it and I put a cooliant temp sensor in a couple days before the o2 sensor.
Jun 10, 2010 at 5:27 PM
Check the fuel pressure if its within 9-13psi this is the specs
Jun 10, 2010 at 5:34 PM
CHEVYG20
  • 8 POSTS
[quote:3e1e88e22b="rasmataz"]Check the fuel pressure if its within 9-13psi this is the specs[/quote:3e1e88e22b]. Ok cool I will test the psi. If it is more then 9-13 psi how do I lower it. Or how do I fix that problem
Jun 11, 2010 at 3:25 AM
CHEVYG20
  • 8 POSTS
[quote:458f582bb0="rasmataz"]Check the fuel pressure if its within 9-13psi this is the specs[/quote:458f582bb0]. Ok cool I will test the psi. If it is more then 9-13 psi how do I lower it. Or how do I fix that problem
Jun 11, 2010 at 3:26 AM
If its over or under replace it-its no good
Jun 11, 2010 at 5:57 AM
CHEVYG20
  • 8 POSTS
[quote:ead19a7237="rasmataz"]If its over or under replace it-its no good[/quote:ead19a7237]. Hopefully I don't sound stupid but what do I replace if it's over or under 9-13 psi. Is it the injectors or maybe the fuel pump that's bad? Thanks
Jun 11, 2010 at 7:09 AM
You need to actually check the fuel pressure to rule out the fuel pump if its within specs-my recommendation is replace the throttle body
Jun 11, 2010 at 11:12 AM
