89 camaro cooling system
TORGO2FAST4U
I have repalced my stock 305 with a (1978) non-egr 350 crate engine. I am getting ready to route my cooling system. I wanted to know if there were any links or pictures that I can get ideas from. obviously my upper hose is going to the water neck, lower into the water pump. My question I guess is how should I route my heater core hoses.
I am using the stock radiator, and the GM performance pump and pully kit.
Thank you very much for any help you can give me.
Torgo2fast4u
Thank you for the info. but maybe I wasn't specific enough. I need to know where to physically attach to hoses. There is a plug in the top of the water pump. There are also 2 holes in my performer intake.(Front left and rear) Can I run my heater hoses from the rear port on intake to the right side of my heater core, and left side of the heater core to the whole on the front of the manifold with leaving the water pump plug in? Sorry about not being more specific in the original question.
Thank you very much for the quick response and all the help.
Torgo2fast4u
[img:2fa619eec7]http://www.2carpros.com/forum/automotive_pictures/102682_051107_2130_1.jpg[/img:2fa619eec7]
[img:2fa619eec7]http://www.2carpros.com/forum/automotive_pictures/102682_100907_1407_1.jpg[/img:2fa619eec7]
Oct 18, 2007 at 12:41 PM
CHEVY22
  • 1,375 POSTS
every time i do a project i buy a roll of hose and run from the engine down by the front of the right valve cover onto the right inner fender and over to the heater core , and you can buy or make your own double hose bracket for the inner fender or you can check the junkyard for one off another car , most have one , no wire ties !!!!
jim
Oct 18, 2007 at 2:09 PM
