I'm tring to fix my horns on "67" Camaro 45,000 miles. I put new forward harness, new horns (Delco Remy), and new horn relay. When I hooked everything up the car ran ok but the horn didn't work. When I left the car and went into the house the horn sounded off and would not go off. I took the horn button off and added new contacts, the kind you see in the book with three pieces, a flat washer type piece, a red plastic spacer type piece and the horn button adapter type piece. I took the steering wheel off and put a new spring and tit and plastic bushing it still didn't help. Everything I try the horn still sounds off as soon as I touch the battery cable to the battery. Whats wrong with my horns (Hi note & Low note)? : :?
Jun 12, 2006 at 8:59 AM
