2010 Chevy Camaro Help with scraping/screeching noise comin
1,000 MILES • 6 CYL • 2WD • AUTOMATIC
MATT79
Everyone I need help. I have a 2010 RS LT2 Camaro. I have taken my car to 2 diff dealerships now. The only thing they have come up with is rocks in my rotors. Occasionally when I am going 5-15mph my car makes a screechy noise coming from the back end. It only makes the noise when my wheels are moving, I even tried... putting it in park and revving my engine. My brakes being pushed doesnt change anything either. Most importantly though it is never consistently there. I do drive over quite a bit of gravel/larger rocks(we had some mine subsidence in our neighborhood) so I am wondering if that is all it is. Please help if you have had this problem, know anyone who has, or have any advice. I can email you a video of it too if that helps. Thanks!
May 11, 2010 at 8:50 AM
LEOMNR2008
  • 22 POSTS
more than likely this is just a bit of normal brake noise or it could be tiny rocks getting stuck between the roters and pads to verify this look at the roters both front and back if you see scrathses in them than its small rocks if not than it is just the pads vibrating on the calipers you can fix this with a can of brake quite but if the noise becomes more presistant than you need to have your breaks checked, and ask the dealership if they would check for a hang up in the rear brakes this sometimes occures in four wheel disk brake systems
May 11, 2010 at 6:07 PM
